#61 |
Re: Is it true that Vegas is DEAD?
SCS also published infos regarding the Quicktime thingy:
https://www.custcenter.com/app/answe...7/kw/quicktime |
#62 |
Vegas is dead and Catalyst is its replacement. This was made clear to me earlier this month and I wasn't even trying to find out about it, just mentioned to me in some conversations.
#63 | |
Ron Ev ans |
#64 | |
#65 |
I think you are relatively safe if you do not let Quicktime player run. Remove all file associations in Windows and remove Quicktime player from running in any of your browsers. That way it should not run for anything. Use other players to play mov files etc. VLC or Windows Media . Which is what I had done some time ago on all my PC's. The library files used by NLE's should not be a problem as far as I understand. I am sure that in the next series of updates all the NLE's will now remove the need for Quicktime.
For most people who do not use NLE's etc then removing Quicktime is a sensible choice and use another player for mov files etc. Ron Evans |
#66 |
i simply renamed quicktimeplayer.exe. everything works - well, apart from the player ;-)
www.lesliewand.com.au |
#67 |
Petition Keep VEGAS Alive!
Petition Keep VEGAS Alive! |
#68 |
Online petitions aren't worth the paper they're written on.
#69 |
Ho ho!
Dave |
#70 |
On another thread there seems to be a reply to a poster from someone at Sony Creative Software support which states that Vegas 14 is being worked on, but there has been unexpected delays.
#71 | |
This is why I spread around that it was indeed dead. But now I'm hearing conflicting reports... |
#72 |
i really can't understand scs's reluctance to come out with the truth. either way the disruption their silence is causing is going to be a major factor in the stream of loyal customers looking elsewhere.
#73 | |
Re the unexpected delays. I am hearing similar stories and that the sudden holdup might have something to do with the QuickTime issue and having to go back into coding to enable support of .MOV files without having to rely on Apple's 32-bit QuickTime support. If that's the case I am more than happy to wait. Time will tell I guess! Chris Young CYV Productions Sydney |
#74 |
Native 64bit ProRes I/O and DNxHD (container independent) I/O would maybe skyrocket them past any other Windows NLE at this point.
It's asking a lot for ProRes but not too much for DNxHD and DNxHR. |
#75 | |
Old Boot
There's a telephone ringing somewhere in Wisconsin but nobody's at home. About time somebody recognised we're here. At best, this is corporate fear. At worst, it's just plain rude. Grazie |
