Top quality for a 45 minute dvd in DVDArch at DVinfo.net
Old January 30th, 2016, 04:18 AM   #1
Hallo friends,
i was wondering if u would use the same settings for this render about a documentary. I shot it with sony FX1 the interviews (about 35 minutes in 1080-50 i), then i shot the landscapes and the aerials from helicopter with D7100 (the other 8 minutes) and 4opro 4 (in 4k downsized in HDV1080 for about 45 seconds cause i loved the wide shots from above).
My workflow has been:
- edit everything in HDV 1080 50 i timeline
Field order UPPER frame rate 25,000 (as i'm in Pal Land)
Full resolution rendering quality BEst
Deinterlace Method: interpolate
Was this the choice u should make considering 85%interlaced material in 50 i and13% shot in 25 p?
Then it comes the authoring part for 45 minutes of DVD:
Variable Bit rate ticked
Maximum 9.500.000
Average (bps): 6.000.000
Minimum 192.000
What do u guys think? It's an important documentary and i was tryng to achieve the best quality
thank u so much for taking time to help me
Old January 30th, 2016, 05:50 AM   #2
Re: Top quality for a 45 minute dvd in DVDArch
I use video CBR 8 Mbit/s for DVD less an hour.
Juris Lielpeteris is offline   Reply With Quote
Old January 30th, 2016, 07:56 AM   #3
Hola
(1)- It has been my experience that the highest quality dvd will be achieved using Tmpgenc Mastering Works to convert your footage to dvd compliant mpeg2. The program has presets which make it very easy to use.
(2)- Once the files have been encoded for dvd usage then I use tmpgenc authoring works to create menu and burn but any authoring tool will be ok
The most important part is (1) the encoding for dvd - any authoring tool can make the actual dvd so long as it does not re-encode or alter the files in any way
I hope this helps.
So I recommend you get Tmpgenc Mastering Works. It will do your current task well and has many other templates for Blu-ray, and every other delivery format you might need
I myself struggled with this for years attempting to get the best quality dvd
Bruce Dempsey is offline   Reply With Quote
Old January 30th, 2016, 12:10 PM   #4
I burned thousands of under 60 minutes DVDs in my days and never went more than 8 for top number, 6 for average and 2 for minimum using VBR. The number of discs that didn't work was maybe 6 and every one was due to a scratched disc.
8 6 2 VBR worked every time.
Don
Old January 31st, 2016, 02:51 AM   #5
This is the best answer for a title under an hour going onto a DVD-R.
Anything above 8 mb/s can be problematic on certain DVD players and given you won't run out of disc space, why drop the bitrate at all? Meaning in this case. VBR encoding is not required. Feed it the max safe bitrate (8mb/s CBR) and call it a day.
Greg Kintz is offline   Reply With Quote
Old February 1st, 2016, 12:29 PM   #6
Hi Marcus. I just add "2 pass" on your variable bit rate setting.... just a little bit longer render time but worth the results....
regards
Enrique Orozco - Sony/JVC/Nikon/Panny cams, DJI/Yuneec drones, VegasPro
www.aerofilm.com.mx
Enrique Orozco Robles is offline   Reply With Quote
Old February 1st, 2016, 03:50 PM   #7
I also use video at CBR 8 Mbit/s for DVD less an hour with 320 kb/s dolby digital audio added to it.
Mark Williams is offline   Reply
