Importing an Image Sequence for Animation at DVinfo.net
Old November 22nd, 2015, 11:29 AM   #1
I am authoring images in another program - POSER - for importing into Vegas Pro 2012.
I am doing so at 24 fps and that is how I have timed it.
When I set up the property timeline does it really matter whether or not I use a 23.976 timing or should I change the frame rate to 24 fps?
My output will be the web and/or bluray. Thanks!
Phil Hamilton
hamiltonp@sbcglobal.net
Dallas, Texas
" I'm shocked, shocked to find that gambling is going on in here! ..."
Phil Hamilton is offline   Reply With Quote
Old November 22nd, 2015, 06:16 PM   #2
Re: Importing an Image Sequence for Animation
if you're exporting an image series it shouldn't make any difference....
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old November 23rd, 2015, 08:23 AM   #3
For the web you could go either way. For Blu-ray, you need to stay with straight 24 fps. So, I wouldn’t change it.
Adam Stanislav is offline   Reply
