BMPCC files don't open in Vegas at DVinfo.net
Old April 2nd, 2015, 08:52 PM   #1
Well, at least in some Vegas version
I have Vegas 12 on one machine and Vegas 13 on another. When I drag and drop a ProRes file from the BMPCC onto the timeline in VegasPro 12 it works just fine. When I try to do it on Vegas Pro 13, it doesn't work.
Any ideas? Right now I wind up copying files across the network to the Vegas 12 machine and rendering them out as Cineform and bringing them back to the original machine for editing. Not an optimal workflow.
I have Quicktime Pro 7 on both machines (although it was installed after installing Vegas Pro, if that makes any difference.)
By the way I googled around and found some info that said older versions of QT would enable Vegas to open the files. I spent (wasted???) an hour fooling around with downloading various old versions of QT and nothing worked.
Just for fun (???) I opened Premiere and Edius and dropped the same files on the timelines and - they both worked just fine.
So clearly this is something Sony could easily fix.Of course I guess I could use Premiere to transcode the clips into Cineform to use in Vegas - or I could just learn Premiere, or use Edius. I've used Vegas forever and I like it but if it won't open the media from our cameras it isn't much use any more.
Old April 3rd, 2015, 10:53 AM   #2
Re: BMPCC files don't open in Vegas
Follow Up
I have an old install of Vegas 9 on the same machine as Vegas 13. Vegas 9 is perfectly happy to open the clips from the BMPCC. Works fine.
I guess it's "Back to the Future" or maybe "Forward to the Past"
Old April 3rd, 2015, 02:26 PM   #3
This is the inherent problem of everyone switching to ProRes, you leave PC editors with limited choice.
No one will ever write native ProRes support on Windows thus why all major projects with ProRes source material on Windows will ALWAYS CRASH or have black frames.
The closest thing to proper Windows support is DNxHD in MXF. And native support for that is only available on Premiere CC.
Jack Zhang is offline   Reply
