Text generator window at DVinfo.net
Old December 9th, 2014, 07:42 PM   #1
I'm not sure if this has been addressed before...
Re the (Legacy) text generator: The text window opens when selected, at a fixed size. Is there anyway to increase the window size?
Normally in PC programs, the size of such windows can be increased by clicking and dragging on the perimeter of the window. However this window does not do that...and you are apparently stuck with the relatively small window...which can be a real pain if you have quite a lot of text...
Renton Maclachlan is offline   Reply With Quote
Old December 9th, 2014, 08:55 PM   #2
Re: Text generator window
Sorry Renton but there's no way that I know of to make that piddly little window bigger :-(
Of course I stand to be corrected but I don't think there is.
Old December 9th, 2014, 09:44 PM   #3
It's something Sony should add to Vegas...make the window size variable...
Old December 9th, 2014, 09:53 PM   #4
Good idea and here's where to ask for it.
Sony Creative Software - Product Suggestions
Old December 10th, 2014, 02:18 AM   #5
The Sony Pro Type Titler plugin has a resizable window - if you can bear to use it, that is . . .! With apologies to those who like it :-)
Ian Stark is offline   Reply With Quote
Old December 10th, 2014, 03:39 AM   #6
Thanks Mike...I've put a suggestion in...
Old December 14th, 2014, 01:26 AM   #7
Another question about the text generator window.
It appears that in it all text is treated as a block...that in regard to some features at least, you can't separate some text from other text. For example, I want to make some text transparent, but not all of it...but I don't seem to be able to make this distinction. If I make any text transparent, it all is. Is there any way to make the distinction?
(I can make some text smaller that the rest, so that is one distinction that can be made...)
Old December 14th, 2014, 04:23 AM   #8
This again is possible in ProType Titler but not within the other Vegas Pro text generators.
Marco Ba is offline   Reply With Quote
Old December 14th, 2014, 10:31 AM   #9
My workaround for such things is to stack another Legacy window on top. I can't explain why, but I am quite happy because of the dumb simplicity of Legacy. :)
Paul
Paul Fierlinger is offline   Reply With Quote
Old December 14th, 2014, 11:40 AM   #10
It's a long time since I used Vegas, so apologies if I'm off beam here, but I seem to remember you need to put each type of text on a serarate track on the timeline and use different effects for each.
Dave
Dave Baker is offline   Reply With Quote
Old December 14th, 2014, 12:58 PM   #11
I want to use transparent text because I don't want any of the other text in the event to move... as it does when you replace a proportional letter with a space. I am then going to put the same words made transparent, on another track so they can be manipulated. Maybe I'll look at Pro Type Titler...
Old June 12th, 2016, 05:02 AM   #12
This is something I would like the new owners of Vegas to look at...
Old June 12th, 2016, 11:27 AM   #13
I view the results on a 2nd monitor as I'm typing, editing, changing attributes, position, etc. It doesn't bother me as much as others. If Magix improves the window, I'll take it, if this improvement isn't on the list of important features and fixes for the next couple version, I'll be good with that as well. But I do understand how this could bother some users.
Best Regards.....George
George Dean is offline   Reply With Quote
Old June 13th, 2016, 02:36 AM   #14
Hi people,
I use VP 13 for just about everything but when it comes to text fx or intros Blufftitler is hard to beat for the price.
Pete Baratta is offline   Reply With Quote
Old June 13th, 2016, 02:53 PM   #15
I'm not sure if it works in Legacy Text for attributes like transparency, but many people don't realize you can highlight specific bits of text and even blank lines with no text while editing, and change the size of the highlighted bits of text or lines between text independently in the same window.
That's helpful if you don't want or need to build two different text sets on two different tracks just to accomplish some size change within the same window.
I often use this for making correct line spacing in between lines of large text. You can create a larger space between grouped lines than a simple return, but not as large as using a blank line (two returns) that is the same size as the large text itself.
You just have to highlight one character of blank space on a line and then set that text size for the line independently of the other lines of large actual characters.
Jay Massengill is offline   Reply
