Question About Cuts Using Multi-Cam at DVinfo.net
Old July 30th, 2014, 11:34 AM   #1
I am using the multicam feature Vegas Pro 10 for the first time but I'm getting quite annoyed at how cuts are being made. I'm not sure what is going here so I am looking for some help.
When making cuts on the fly during the video preview (to switch from one cam to another), sometimes Vegas will make the cut at the current "live" position and sometimes it will make the cut at the previous "cursor" position where the video had last been paused or stopped. I can't for the life of me figure out what rhyme or reason Vegas is doing this to me. I am using CTRL plus a mouse click to switch cams and include a cross fade.
Anyone have any ideas here? Can you understand what is going on from my description of the issue I am having?
Brad Ridgeway is offline   Reply With Quote
Old July 30th, 2014, 08:55 PM   #2
Re: Question About Cuts Using Multi-Cam
I've never had that happen, but I usually don't try to cut on the fly. I move to where I want the cut to be and click the angle on the quad view. Once I have all my cuts, I then go back and change some to crossfades manually.
Jeremiah Rickert is offline   Reply With Quote
Old July 31st, 2014, 12:07 AM   #3
Click away from the timeline before moving to the Multicam window.
This will apply cuts at the cursor position rather than your last marked cursor position on the timeline.
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old August 1st, 2014, 07:18 PM   #4
Brad,
I've been experiencing the same frustration lately with Vegas multi-cam. It seems to lose focus on the timeline much easier than in the past versions and when it loses focus it will make the cut where you started playing. It's hard to nail down but it does not seem to operate the same. I have not gone back and tested older versions but for example Ctrl + s will do it. I think also just using the mouse scroll while the video is playing will cause it to lose focus.
I'd let Sony know and see what they say. Sometimes they fix things and other times bugs go on with no end in sight. I had luck once with a trimmer bug being fixed quickly by making a demo video showing exactly what I was experiencing and comparing it to a previous version of the software. I e-mailed it to tech support and they fixed it the following version.
Marc Salvatore is offline   Reply With Quote
Old August 23rd, 2014, 05:26 PM   #5
I use VASST InfinitiCam. It's very easy to use.
infinitiCAM
John 14-6 Jesus said to him, “I am the way, and the truth, and the life. No one comes to the Father except through me.
Brian Berg is offline   Reply With Quote
Old August 25th, 2014, 08:48 AM   #6
Sponsor: JET DV
Or you could take a look at the original Multi-cam available in Excalibur.
Old August 25th, 2014, 03:21 PM   #7
+1 excalibur
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old August 25th, 2014, 09:56 PM   #8
And another vote here for Excalibur. I've been using it since the early version for multicam.
Thanks Edward!
Ken
Ken Plotin is online now   Reply
