Rendering problem with Sony Vegas 12
Hi all - I'm having a really annoying problem and am desperate to solve it. I have to deliver this to a client tomorrow and I can't figure out why this is happening. I'm rendering up a video file but when I do the cuts are bleeding into each other for a single frame. It isn't like this on the time line, I can't figure why this is happening. I'm splicing up a MOV file and grading it using inbuilt Sony Video FX and Magic Bullet. Here is an example...
Any ideas anyone? |
Re: Rendering problem with Sony Vegas 12
Quantize to frames checkbox (Alt+F8)?
Agree...check quantize is ON.
Thanks a million for the help - I thought that would be the solution but the problem is still there after doing overnight renders... sigh... I'll keep trying!
#5 |
It is not enough set checkbox to on, you need to check and tune all cuts if neccesary.
#6 |
Second that suggestion. Yes check and tune all cuts. Especially if it's Canon DSLR footage as I have seen many clips that don't end on frame boundries as often the GOPs aren't closed when the camera stops recording and you end up with these weird half frame ends to many clips.
Chris Young CYV Productions Sydney |
