Mike Crash' De-interlace filter notes - Page 2 at DVinfo.net
Old December 5th, 2005, 09:10 AM   #16
what are you guys talking about, an effect in a video?
Jim Rog is offline   Reply With Quote
Old December 5th, 2005, 09:42 AM   #17
Sponsor: JET DV
It's an effect you add to your video which helps clean up video noise. It's based on a tool for Virtualdub. All of Mike's tools can be found here:
http://mikecrash.wz.cz/vegas/vegas.htm
Old December 5th, 2005, 10:07 AM   #18
The Mike Crash "smooth" and 'noise reduction" filters work for a while, then cause errors and finally, a crash (no pun intended) with Vegas 4.0e.
I removed the filters and all was well again.
FYI.
Ken
Ken Plotin is offline   Reply With Quote
Old December 5th, 2005, 10:28 PM   #19
FYI.
Ken
I don't have problems in Vegas 6.
BayTaper.com | One man's multimedia journey through the San Francisco live jazz and creative music scene.
Bill Binder is offline   Reply With Quote
Old December 6th, 2005, 02:47 PM   #20
thanks
jim
Old August 31st, 2007, 03:55 PM   #21
Works OK with resize etc when used as MediaFX
Originally Posted by Laurence Kingston View Post
A couple more comments:
You can't resize or change aspect ratio when using the Mike Crash deinterlacing filter. If you do it will resize the interlace lines which looks absolutely horrible.
Just tried v1.0.3 of this filter in Vegas 7d. When applied as a MediaFX, it worked fine (combing was seen to be removed) even when resizing or changing aspect ratio.
Only a problem when applied as a TrackFX or EventFX - when it appeared to have no effect.
My settings were:
Frame-and-Field differencing, Compare color channels, Use cubic, Motion map denoising.
David Esp is offline   Reply With Quote
Old September 1st, 2007, 08:33 AM   #22
Updated link to Mike Crash website
Mike Crash's website for Vegas plugins is now at
http://www.mikecrash.com/modules.php...ownload&cid=13
The current plugin versions are dated 23 June 2006.
Douglas Clark is offline   Reply With Quote
Old March 30th, 2009, 04:27 PM   #23
First, I'd like to thank all of you for making Mike Crash's plugin known, and to Mike for writing this fantastic technology. This deinterlacer has saved all of my 480i footage. WOW. So, I'm going back and redoing my projects. So far, I've had great results with my 480i60 footage converted to 480p30 from JVC and SonyVX2000. My 1080i60 (Sony EX1) -> 720p30 also improved. The trouble remains with my m2t 1080i60 HDV files (Sony Z1). It seems as if no project or render settings yield deinterlacing, but the artifacts are larger - probably the resize problem someone mentioned earlier. So, I find that I have to render to Cineform 1080p30, then open another project to resize to 720p30. Has anyone been able to render directly from the 1080i60 HDV (1440x1080) to another video size?
Gints Klimanis is offline   Reply
