Recently used transitions menu at DVinfo.net
Old July 3rd, 2013, 07:27 AM   #1
When right clicking on a crossfade on the timeline a menu appears. In that menu is a sub-menu, Transitions, and I use it constantly. This contains the controls for Convert to Cut and Insert Crossfade, as well as a list of what you would think would be the most recently or most frequently used transitions, or perhaps a list of favourite transitions. Only they aren't (in my case, anyway.) I probably use three or four different transitions at most, and none of those are displayed!
I thought perhaps that by using a particular transition a number of times in a row it might appear on the list. Nope. I can't see any logic behind the transitions it chooses to include.
While it's not a major hardship to click on Insert Other, then choose from the plugin chooser, it's frustrating, as I know I could be doing it in less keystrokes.
Is there any way to change the contents of that list?
Ian Stark is offline   Reply With Quote
Old July 3rd, 2013, 09:38 AM   #2
Sponsor: JET DV
Re: Recently used transitions menu
Actually, it does appear that it's a "MRU" list. I just looked in the the "Internal Preferences" and there is an MRU list there for the transitions and they are showing the list that I see. Unfortunately, you need to know the GUID in order to change them manually.
Try this:
1. Go to the transitions tab.
2. Now drag the transition preset you want to use to a transition
3. Now right-click the transition and see what's in the list
Old July 3rd, 2013, 07:53 PM   #3
Thanks Edward, I'll try that.
Old July 3rd, 2013, 08:53 PM   #4
My experience shows that Vegas 12 has problems remembering Vegas window layouts & transition lists. These problems were not in Vegas 11.
Kate Spiegel is offline   Reply With Quote
Old July 8th, 2013, 05:07 AM   #5
Edward, yes that's it. If you select them from the Transitions chooser window (which I rarely do) they then show up in that quick menu. Excellent! My life is complete. Many thanks. :-)
