Welcome to the HDV-Vegas forum! - Page 2 at DVinfo.net
Old October 27th, 2006, 09:24 AM   #16
Motherboard
Originally Posted by Marco Levi
hi i am marco, i have buy a new cpu dual core amd 2x4800 for my not linear video system based on new vegas 7 and hdv video format.
it is available a hotfix for windows xp sp2 for best performance with processor dual core amd ????
is true be exist a sw utility of amd for best performance with dual core cpu ???
i am waiting your reply.
sorry for my english
ciao m.
I suggest makign sure your motherboard & chipset drivers are up to date. WinXO Pro SP2 can handle a multi core system (same as hyperthread) but you probably need to check with your motherboard manufacturer to make sure the latest drivers are available and installed.
as far as anything from AMD, unless AMD made the "northbridge" chip and the reference motherboard, then you probably don't need anything from them.
Make sure you are using WinXP Pro, because XP Home (asside from being annoying), might not handle dual core CPUs the same as XP Pro. Someone correct me if I am wrong on that.
jason
Jason Robinson is offline   Reply
