mp3 issues at DVinfo.net
Old May 7th, 2013, 02:51 PM   #1
mp3 issues
I am using mp3 audio clips in a video, and near the end of the clips, about 5 or 10 seconds from the end, the audio ends abruptly, even though the waveform on the timeline shows remaining audio.
Is there a workaround for this issue? I used to overcome this problem by putting the mp3 in it's own project, rendering it as an .wav file, and it would be fine, but that doesn't work any more.
Old May 7th, 2013, 04:21 PM   #2
Re: mp3 issues
Possibly this is related to different sampling rates on your MP3 files vs. your project audio?
Try a render of your MP4 to a 16bit / 48KHz wav?
Kinda' guessing about this, but differing sample rates in audio files can sometimes have odd implications for duration...
Old May 7th, 2013, 04:32 PM   #3
Re: mp3 issues
I'll try it, thanks Seth.
Old May 7th, 2013, 05:16 PM   #4
Re: mp3 issues
Jeff. Did you see that I uploaded the project?
Kim Olsson is offline   Reply With Quote
Old May 7th, 2013, 06:08 PM   #5
Re: mp3 issues
Kim, I did not, I'll check it out. I'm furiously working on a video this evening, I'll check it out asap, thank you!
Old May 9th, 2013, 11:12 PM   #6
Re: mp3 issues
I know this is not much help, but I keep vegas 9 loaded up for those mp3 emergencies. Vegas 9 seems to work perfectly with mp3s where I have run into crazy issues with everything above under certain conditions while dealing with mp3s.
Joe Kollee is offline   Reply With Quote
Old May 12th, 2013, 10:13 PM   #7
Re: mp3 issues
My work around is converting every mp3 I plan to use in a project to .wav
As a matter of fact, all my songs are in .wav format due to similar audio issues.
Old May 12th, 2013, 10:23 PM   #8
Re: mp3 issues
James, can you recommend a converter? I used to use Vegas to do this, but it doesn't overcome the issue I'm having.
Old May 12th, 2013, 11:34 PM   #9
Re: mp3 issues
Winnydows XVID4PSP v6 (requires MS Silverlight).
Winnydows Home
Juris Lielpeteris is offline   Reply
