Why is my quality so bad? at DVinfo.net
Old April 5th, 2013, 09:27 AM   #1
I use this tutorial:
High quality video for YouTube and Vimeo from Sony Vegas
Its extremely good and professional. I suggest you have a look.
(NOTE: I remove the Lanczos thing due to my video being the correct size anyway).
Anyways, I record cod clips, but my output is terrible.
Here are my in game settings
1024x768 (:<) (NOTE: I can "downsample" to 16:9 1920x1080, looks better, but no point as my quality is terrible. However, the vid at the end is recorded @ 1920x1080)
4:3 Ratio
4xAA
Max settings in terms of textures etc.
My nvida control panel.
http://gyazo.com/813d3e9d3a6848a2428eaf2c8af6be25.png
http://gyazo.com/41dd2fdcb25398779e268bfbc77a7ddb.png
In game, I put the timescale to 0.1 and record @ 60 fps.
Speed it up in vdub = 600 fps. No compression (uncompressed), no audio.
Vegas render settings.
http://gyazo.com/217bf37d72f168edd629844a4c977c6c.png
Blend fields as in the bubble vision guide. 60 fps due to 600/10= 60.
Render with Frameserverdebug so no need to render out and therefore keeping quality.
Megui settings:
http://gyazo.com/07f6c3c7a3d8eff9f6a...png?1365173310
This is my result
1280x720-QTGMC-ST-muxed - YouTube
Why is the quality so bad? Btw, no audio for it. Is it the megui settings? Did I do something stupid?
This person uses Xvid compression codec In sony Vegas, records @ 1920x1080 and renders into 1280x720.
Example of his quality:
Why is mine so bad, is it the compression, the codec? Should I be using Xvid, not megui?
Cheers
John Freddy is offline   Reply
