What player do you use? at DVinfo.net
Old December 17th, 2012, 02:46 AM   #1
I just finished rendering a 19-minute video with the following specs:
Sony AAC/AVC mp4
1920 x 1080i
VBR 20,000,000 Maximum
VBR 14,000,000 Average
Resulting mp4 video file is 2.3 GB
My player, Arcsoft Total Media Theater 5 cannot play it. Error message says "Unsupported format". I tried VLC player, didn't work, either.
Should I try another player? Any suggestion?
Thank you,
Norris Combs is offline   Reply With Quote
Old December 17th, 2012, 03:25 AM   #2
Re: What player do you use?
i simply use both wmp and vlc.
a. i would think the vast majority of my, and my clients audiences have what came with their pc, usually wmp - whatever i produce HAS to play in wmp.
b. vlc is my fall back position for testing. it's also free so i can happily recommend it when needed.
what is the proposed use of your video, net, blu-ray, etc.,?
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old December 17th, 2012, 03:46 AM   #3
Old Boot
Thank you,
Eh? . . . . Why not try the other way around? What does the Player supposed to play?
Grazie
Old December 17th, 2012, 03:59 AM   #4
Old Boot
Is this your player? This is purely software NON hardware solution? Yes?
Tips for TotalMedia Theatre 5 Settings
Have you tried the file association options?
But, as Leslie suggests. Keeping it simple is not a bad idea. However, is this s/w on a hardware solution?
Grazie
Old December 17th, 2012, 02:22 PM   #5
Just out of curiosity, I rendered a very short segment of my project, to the same specs, but the length is only about 30 seconds long. It played fine with Total Media Theater and VLC. Somehow I suspect that the jpegs I have at the end is to blame. I have my video so that at the very end, a bunch of jpegs are played as a slide show. I'll try adding some jpegs to the 30-second video clip, and render again, and see if it plays.
Old December 17th, 2012, 04:34 PM   #6
Try splash lite or even pro!
Let me know
Old December 17th, 2012, 10:21 PM   #7
Let me know
Marcus,
I d/l Splash Pro, didn't work.
Please see following post for some more info.
Thanks for your suggestion,
Old December 17th, 2012, 10:22 PM   #8
Just as I suspected, the reason the mp4 file didn't play is due to the jpeg slideshow at the end of the video. I re-rendered the project with just the video, and it played fine.
Anybody have any idea why the jpegs caused the "Unsupported format" error message?
Just to throw in another variable: I rendered the video WITH slideshow, but at a lower bitrate to upload to Vimeo, and it's playable on Vimeo. Not sure of the significance of this piece of information, maybe irrelevant.
Old December 18th, 2012, 02:45 AM   #9
No, however I use a large number of still images in most of my shows and I use the PNG format instead of JPEG by default. I prefer PNG because of its greater flexibility, mainly because it supports transparent backgrounds and that gives more options for placing multiple images within the same view.
I convert JPEGs to PNGs using a Photoshop batch action which also resizes and sharpens the JPEGs but you could just save as PNGs.
Pete
Peter Riding is offline   Reply With Quote
Old December 18th, 2012, 04:02 AM   #10
appa5rently vegas is png friendly - i never use anything else.
Old December 18th, 2012, 03:43 PM   #11
I will redo it as png and see.
