Loading clips to Vegas at DVinfo.net
Old July 28th, 2012, 01:23 PM   #1
I have Vegas 9E. When I go to open up clips to vegas and load them in the time line there is no video. If I load them individually I get video. It will be a daunting time consuming task if this is the workflow. The clips are off Canon 7d so they are mpeg 4?
Making Family Videos Not To Look Like Family Videos
Fred Foronda is offline   Reply With Quote
Old July 28th, 2012, 04:56 PM   #2
Jubal 28
Re: Loading clips to Vegas
Not sure I understand what you're doing.
What's the difference between opening up the clips in Vegas, and loading them individually?
David Jimerson is offline   Reply With Quote
Old July 29th, 2012, 06:50 PM   #3
Fred, Vegas 9 is not optimized to handle Canon DSLR footage, that could be your issue. To many events on the timeline will be problematic.
You should use Proxy Stream to convert your footage to either XDCAM 35 or 50mbps or use a plugin like Epic I or move on to Vegas 10 or 11 which are really optimized for DSLR footage and use your footage right off the timeline, no conversion.
Robert St-Onge is offline   Reply
