h264 tips and tricks - Page 2 at DVinfo.net
Old June 28th, 2012, 02:52 AM   #16
Re: h264 tips and tricks
Hi
Couldn't get to the link, it says private video.
The AC3 file seems odd, when I use MediaInfo.dll library in the code to check it's file format it returns nothing, so the code can't confirm it is an AC3 file. I'll continue to have look to try and resolve it.
Regards
Phil
Phil Lee is offline   Reply With Quote
Old June 28th, 2012, 04:02 AM   #17
sorry, wrong privacy setting, my bad.
fixed now.
Its basically rendering very fast and the output file is 0 kilobytes.
Ill try an ac3 from a different encoder.
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old June 28th, 2012, 04:56 AM   #18
Hi
I'm wondering if it is an issue with the Cineform support. Can you try outputting to Lagarith and see if that encodes? Also if you can post a few seconds of sample output of the Cineform video I'll give that a go. Have you installed AVISynth?
Regards
Phil
