Problem installing Vegas Pro 11 32 bit upgrade at DVinfo.net
Old March 21st, 2012, 08:40 PM   #1
I just purchased the Vegas Pro 11 upgrade and attempted to upgrade from Ver. 10e. The 64-bit version installed with no problem however the 32 bit version will not run after installing it. When I attempt to run it, there is a text dialog box that is just ASCI text. It is on screen for just a split second and goes away before I can read it. Any suggestions?
Jim Snow is offline   Reply With Quote
Old March 21st, 2012, 08:45 PM   #2
Re: Problem installing Vegas Pro 11 32 bit upgrade
Reinstall Vegas32 and try again.
Then, if that doesn't work,
Uninstall, reinstall and try again.
Old March 21st, 2012, 08:46 PM   #3
I have already tried that and have the same problem each time.
Old March 21st, 2012, 08:48 PM   #4
I might be missing something, but if you have the 64 bit version, why would you need the 32 bit version?
Justin Molush is offline   Reply With Quote
Old March 21st, 2012, 08:53 PM   #5
Some plug-ins and filters are only 32 bit and will only work on the 32 bit version of Vegas.
