render settings for master file from which to make multiple renders at DVinfo.net
Old March 11th, 2012, 11:43 PM   #1
Hi folks!
I'm required to make multiple formats of my edit for uses that include web streaming, DVD production, and other non-broadcast uses.
Since each render is taking a little more than 30 minutes I thought it would be wiser to first render out my timeline as a master file and then proceed to render out the single video in the multiple formats that are required. I know I lose a generation but the trade-off is well worth it.
So the question is, what render settings should I use to have the best quality master file? Something that preserves quality enough and doesn't crumble when resized.
I'm using Vegas Pro 11 and footage is from my Canon T2i camera.
Windows 7 Ultimate 64-bit // i7 2600K // 16GB RAM // ASUS P8P67 Board // NVIDIA GTX 470
Sony Vegas Pro 13 // Adobe Premiere Pro CC 2014 // http://vimeo.com/alijafri
Ali Jafri is offline   Reply With Quote
Old March 12th, 2012, 12:31 AM   #2
Re: render settings for master file from which to make multiple renders
Use the standard "Batch Render" script ;)
Aleksey Tarasov is offline   Reply With Quote
Old March 12th, 2012, 02:09 AM   #3
i use the Avid DNxHD codec for my final version of a video. It can be downloaded for free here: Avid Codecs 2.3.7 Download
Iker Riera is offline   Reply With Quote
Old March 12th, 2012, 02:34 AM   #4
what's the problem simply rendering from the tl?
i rarely render a 'master' file, but when i'm asked to do so i use .mxf
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old March 13th, 2012, 07:51 AM   #5
If I had to render a master, I would render the video to a sequence of PNG images, which are compressed but their compression is lossless, so you get the highest possible quality. And I would render the audio as a WAV file at the best settings (of the best source audio), such as 96 kHZ sampling rate, 24 bits.
Of course if my health weren’t so bad, I would use the codec I developed just for masters several years ago but never actually coded it. And probably never will unless someone finds a cure for diabetes in the very near future.
Adam Stanislav is offline   Reply With Quote
Old March 13th, 2012, 02:39 PM   #6
everyone has their preference, but for me
YUV, i'd go with DNxHD (either 175 or 115, depending on frame-size)
sRGB, i'd pick PhotoJPEG 100%
Rob Wood is offline   Reply
