How to get this file to load in vegas? at DVinfo.net
Old February 29th, 2012, 01:50 AM   #1
Hey, I've tried several different routes on this file format, but can't get it to work in Vegas. Here is the info from Mediainfo. can anyone help? I've installed the codec on my computer, but Vegas still won't load it. VLC plays the file just fine. Any suggestions would be most welcome! Thanks!
ideo
Format : MPEG-4 Visual
Codec ID : MP42
Codec ID/Info : Microsoft MPEG-4 v2 (pre-standard)
Codec ID/Hint : Microsoft
Duration : 1mn 9s
Bit rate : 50.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.805
Stream size : 417 MiB (100%)
Jeremiah Rickert is offline   Reply With Quote
Old February 29th, 2012, 11:21 AM   #2
Re: How to get this file to load in vegas?
Why don't you upload the clip somewhere so someone can download and check it out - and if they're really nice they could transcode it for you so that it runs in Vegas.
Windows 7 Ultimate 64-bit // i7 2600K // 16GB RAM // ASUS P8P67 Board // NVIDIA GTX 470
Sony Vegas Pro 13 // Adobe Premiere Pro CC 2014 // http://vimeo.com/alijafri
Ali Jafri is offline   Reply With Quote
Old February 29th, 2012, 12:44 PM   #3
Since it is a Microsoft codec, are you up to date on your installation of Windows Media Player? Vegas gets some of its codecs from WMP.
Also, make sure "automatic codec download" is selected in WMP prefs, and open the clip in WMP. If it plays there, it *should* play in Vegas.
There is also an expansion codec pack for WMP, but I can't find the current version at the moment. DO NOT download any codec pack other than one that's on microsoft's website. Third-party distributed codec packs are a notorious source of spyware and bad codecs.
Old February 29th, 2012, 02:36 PM   #4
I have ways of transcoding it if I need to, but I'd rather not have to take that step. The files will work, for example, in Premiere CS3.
