Error when rendering AVC at DVinfo.net
Old February 22nd, 2012, 04:02 PM   #1
Hi,
I have a 1080 30P (29.97) project. Every time I try to render Sony AVC (mp4) it goes along for awhile and then stops with an error that basically says "error - no other information is available" or something to that effect.
Whatever it does render up to that point is "there" and will play up until the error point. I do notice however that this partially rendered file had no audio with it even though all audio is set-up to be there. There is nothing in the Vegas timeline to explain why it stops where it does - in fact - it is in the middle of a fairly simple clip/event.
This project renders fine to AVI and WMV as HD - haven't checked any others. any explanation for this?
also - separate question - I notice that few/none of the rendering presets seem to have a 1080 30P option as one of the built-in ones - i have to make my own .... is this some sort of non-standard setting or something? It's what I generally shoot at.
KenM
Ken Matson is offline   Reply With Quote
Old February 24th, 2012, 07:51 AM   #2
Re: Error when rendering AVC
bump? Anyone?
KenM
Old February 24th, 2012, 08:07 AM   #3
Originally Posted by Ken Matson View Post
bump? Anyone?
Probably not. It is hard to say something when you told us nothing about your operating system and what version of Vegas you are using, and things like that. Not that I would be able to help you with this problem, but someone else might if you posted that information.
Adam Stanislav is offline   Reply With Quote
Old February 24th, 2012, 08:29 AM   #4
Sorry - Vegas Pro 11 64bit
I'm on a quad core x2 i7-2600 3.4G with 16G memory and 2- 2TB drives + a 500G system disk
KenM
Old February 24th, 2012, 03:19 PM   #5
Try saving the project, exit Vegas, restart Vegas, render project.
Mike Hinkel is offline   Reply
