Can't read what I've rendered? at DVinfo.net
Old January 18th, 2012, 09:16 PM   #1
Never mind, figured it out.
Jeremiah Rickert is offline   Reply With Quote
Old January 19th, 2012, 11:04 PM   #2
Old Boot
Re: Can't read what I've rendered?
Care to share? Might help others too?
Cheers
Grazie
Old January 19th, 2012, 11:15 PM   #3
i often can'r read what i've written......
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old January 25th, 2012, 01:37 AM   #4
Hehe. Well, I was having problems with re-importing AC-3 files back into Vegas after they were rendered. I still can't open an AC-3 file in Vegas.
I just ended up exporting a .wav file and I'll re-export the entire project as an AC-3 file before I go to the DVD authoring stage.
Thanks for the concern :p
JR
Old January 25th, 2012, 02:09 AM   #5
glad you got it sorted.....
Old January 25th, 2012, 09:31 AM   #6
Sponsor: JET DV
Jeremiah, Vegas will not load AC3 files. The one exception to that is if you import a DVD, it will then read the AC3 audio from those MPEG2 files but it has never imported straight AC3 files.
Old January 27th, 2012, 04:13 PM   #7
Yup, it just seems weird that it will render to a codec, but won't then read the file it's rendered. I can't, for example, open m2v files either, and I'd really like to be able to put one of them into my timeline without conversion.
Old January 28th, 2012, 08:24 AM   #8
Sponsor: JET DV
You may be able to open m2v files by renaming them to mpg.
Edward Troxel is offline   Reply
