Menu not Displaying Properly at DVinfo.net
Old December 27th, 2011, 12:39 PM   #1
Hello All,
Every time I open Sony Vegas Pro 11.00 (511) the Menu that contains File Edit View... doesn't display properly; the menu is cut off and the Font size too large so I can partially see what appears to be Fil (File) Ed (Edit) etc. I am running this program on Win 7 Home Premium 64 bit. The screen resolution is set at...wow...that was wierd. I just set the resolution back to 1600x900 and the menu displayed properly. Ugh. I closed the program and when I restarted it has same problem again. This is frustrating. Any suggestions?
Thank you.
NOTE: Every time I make a change to another resolution setting it displays find for a moment. When I close the program and open it up again, problem reoccurs.
Jack-of-all-trades trying to master one (Videography)
www.sdfvideo.com
Albert Rodgers is offline   Reply With Quote
Old December 28th, 2011, 07:45 AM   #2
Sponsor: JET DV
Re: Menu not Displaying Properly
Is your display settings set to "large fonts"?
Edward Troxel is offline   Reply
