Output file renders single frame only at DVinfo.net
Old November 27th, 2011, 12:13 PM   #1
This is driving me nuts: suddenly any clip I render out, either as an mp4, or wmv won't render all the frames. Somehow the video clips playback only the first frame. What happened? The clips playback properly from the Vegas timeline, but as I render a loop I can already see on the preview window that only the first frame is being rendered. I need help in a hurry -- anyone here today? I'm on Vegas 11; 64bit; Windows 7. My clips are imported uncompressed AVI files from an animation application.
Paul
Paul Fierlinger is offline   Reply With Quote
Old November 27th, 2011, 02:09 PM   #2
Re: Output file renders single frame only
Besides rebooting my computer and all the other tests, such as loading another project etc and getting nowhere, I uninstalled and reinstalled Vegas 11 with no change! I'm desperate; I have to have this rendered today, and I remembered I still have Vegas 10 and it works! I can render video files again. The problem lies with Vegas 11 and most likely a setting I inadvertently tripped without being aware of doing so. Can anyone think of a button, a setting of the render As function that would want to prevent Vegas from rendering all frames? Who would need that? Still stumped.
Paul
Old November 27th, 2011, 02:36 PM   #3
I figured it out. I was using a shortcut button on my Wacom tablet that was set to CTRL SHIFT M but somehow was not sending out that command. It was activating Render properly but deselected the loop bar to a single frame. I wasn't seeing this happen because the clip was covered by the Render As Panel. After reentering the same command into Wacom all is working again. It figures that the culprit was Wacom -- their software is never up to anything good.
Paul
Old November 27th, 2011, 08:53 PM   #4
Glad you got it solved!
Adam Stanislav is offline   Reply With Quote
Old November 27th, 2011, 09:04 PM   #5
Thanks, Adam. What still baffles me is, if my shortcut button made the loop bar jump to a single frame, how did the Render As know when to stop? This was one of the reasons it was so hard for me to locate the source of the problem; everything worked as should except for not rendering all the frames.
Oh well, I don't expect anyone here ever running into this one.
Paul
