HDV1080i -> 1080 24p in Vegas at DVinfo.net
Old August 30th, 2005, 07:32 AM   #1
Hi,
I know that this subject has been discussed number of times on this and other forums. However, I can not find any clear description on how to actually do it.
Douglas described how to do "standard" 24p conversion in Vegas but what templates do I use for my project and how do I render my project if I use HDV not DV? I am still not 100% clear. Also, how do I downconvert resulting 1080-24p to NTSC/PAL DVD (also 24p)? There is many solutions but which one is the best?
Any help would be greatly appreciated
Regards,
Wojtek
Wojtek Tryc is offline   Reply With Quote
Old September 1st, 2005, 03:45 PM   #2
Originally Posted by Wojtek Tryc
Hi,
Regards,
Wojtek
Anyone?
Thx,
W
Old September 1st, 2005, 08:35 PM   #3
I'm no expert, but using a regular 1080i template, just render as 24p 2:3 avi.
Seems too simple, maybe I'm wrong.
Kevin Red is offline   Reply With Quote
Old September 1st, 2005, 10:59 PM   #4
MPS Digital Studios
Gearshift:
http://www.vasst.com/search.aspx?text=gearshift
heath
My Final Cut Pro X blog
Old September 2nd, 2005, 06:28 AM   #5
The regular template for rendering supports either NTSC/DV and 24p or HDV 60i...
How do I specify 2:3 with HDV resolution...
Wojtek
Old September 2nd, 2005, 06:31 AM   #6
Originally Posted by Heath McKnight
Yes, I know...but I would like to understand it first then I can decide what I need to purchase to automate the process...
WOjtek
Old September 2nd, 2005, 08:50 AM   #7
WOjtek
GearShift will convert the footage to 24p properly if you use it prior to editing your HDV.
Rendering your HDV for downconversion to SD 24p is the easiest thing in the world. Just render to the MPEG 24p template in Vegas. For PAL, you'll just want to change the project properties of Vegas to PAL widescreen, and then apply a pan/crop (using a script tool is best) and render in the same way.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
Old September 2nd, 2005, 01:14 PM   #8
Douglas,
I understand how to reneder to SD (24p) as I can use one of the templates available in Vegas, but how about creating 1080-24p file?
Wojtek
Old September 3rd, 2005, 08:38 AM   #9
GearShift
I just purchased GearShift, Thank You
Wojtek
Old September 3rd, 2005, 10:37 AM   #10
To render to 24p, you can use GearShift, or you can simply use the template that you'll notice GearShift has added to your templates. Just choose the 1080 24p template in the Render options.
Douglas Spotted Eagle is offline   Reply
