Two minor config problems with Vegas Pro 11 at DVinfo.net
Old November 6th, 2011, 04:36 PM   #1
Hi,
I bought the upgrade to Vegas Pro 11 last week and there are 2 configs I just don't remember how to change. I'd like to have the clip filename displayed in the clip itself in the timeline. Since I'm working with a lot of short clips, this is very helpful for me. Where can we find this setting?
Also, I've noticed each time I click on the Event FX button inside a clip, not only it opens up the Event FX dialog box but the Event Pan/Crop window too. Is there a way to avoid this? I don't recall having this problem with previous version of Vegas.
Benoit
Benoit Bissonnette is offline   Reply With Quote
Old November 6th, 2011, 05:29 PM   #2
Sponsor: JET DV
Re: Two minor config problems with Vegas Pro 11
1. View - Active Media
2. This is a new feature in Pro 11 (and one I like). In Pro 10, they added the Pan/Crop entry on the FX list where you could easily place and FX before or after pan/Crop (Previously you had to click on the little "pre/post" triangle that many did not know even existed). In Pro 11 they've added the ability to click on the Pan/Crop button and get directly to the Pan/Crop screen without having to exit the FX window and then open the Pan/Crop window.
Old November 6th, 2011, 07:10 PM   #3
Hi Edward,
Thank you very much with your quick reply. I fixed the first problem.
As far as the second problem is concerned, is there a way to put it back like it used to be in previous version? For the type of editing I do, or unless I don't understand the advantages of having both windows to open at the same time, I find that pretty annoying.
Best regards,
Benoit
Old November 7th, 2011, 07:25 AM   #4
Sponsor: JET DV
No, you can't change it back. Both aren't actually open "at the same time" - it's now a single windows where you can easily switch between all FX AND pan/crop. It's actually easier especially if you're wanting to switch from an FX to pan/crop and back. Plus it's a visual way to determine if the FX is applied before or after pan/crop is applied. If you don't click on Pan/Crop in the row across the top, you won't even see the pan/crop screen except for when you remove all FX - then just close the window and you're done.
Edward Troxel is offline   Reply
