Vegas support at DVinfo.net
Old October 26th, 2011, 10:25 PM   #1
Vegas support
Anyone know if Vegas can support a command line interface. I want to use my render farm with Vegas but I don't know if it can handle it. If it can, are there any doc's on it?
Jack Duggan
Jack Duggan is offline   Reply With Quote
Old October 26th, 2011, 11:20 PM   #2
Re: Vegas support
there USED to be a 'built-in' network render, but for reasons best known to scs it was dropped.
with fast cpu's, gpu's, etc., i presume they thought it superfluous.
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old October 27th, 2011, 02:26 AM   #3
Re: Vegas support
Yes, that's a shame. Now that I have two fast pcs, fast ethernet etc I had wanted to try it out for real (only did a few tests some years ago). When was it dropped? This version?
Ian Stark is offline   Reply With Quote
Old October 27th, 2011, 03:31 AM   #4
Re: Vegas support
don't remember exactly (7?), but i tried it vs my reasonably powered pc at the time and found it quicker to just let the pc get on with it and use the other for general use while my main pc was rendering.
i don't think given the power of i7's and such that network rendering would make much of a difference really...
Old October 27th, 2011, 08:33 AM   #5
Sponsor: JET DV
Re: Vegas support
Jack, the short answer is YES. But in order for it to do anything you would need the command line to automatically start a script (which can be done) that can then do whatever processing you need done. The script can even shut down Vegas when finished.
Old October 27th, 2011, 02:14 PM   #6
Re: Vegas support
Thanks Guys, I spoke with Sony, hoping to get some info. or doc's regarding this. They said yes it can be done and No we don't have any Doc's. So I guess it means some more research. Any Idea's where to start?
Jack Duggan
Old October 28th, 2011, 09:19 AM   #7
Sponsor: JET DV
Re: Vegas support
You can start Vegas and have it automatically run a script using a batch file containing something similar to:
"c:\Program Files\Sony\Vegas 11.0\vegas110.exe" -SCRIPT:"c:\MyScript.cs"
Old October 29th, 2011, 01:59 AM   #8
Re: Vegas support
Thanks Ed, I'll keep working on it. Have a good one
Jack Duggan
