Capture help needed please? - Page 2 at DVinfo.net
Old October 17th, 2011, 02:39 PM   #16
Re: Capture help needed please?
Sure, I agree with you Tim. As I said, I didn't think it was going to be of any help in your situation. I was only posting it in case it helps other people who are having firewire trouble and come across this thread.
Ian Stark is offline   Reply With Quote
Old October 19th, 2011, 09:24 AM   #17
Old Boot
Tim, you've got 2 FW ports on that card. What are you using each for?
Grazie
Old October 19th, 2011, 09:52 AM   #18
Tim, if you haven't already, try capturing without the external firewire hard drive attached to the card. Many years ago I had a problem with an old canon XM2 (GL2) which, when attached to the card at the same time as my firewire drive, caused what someone described as a 'data storm' on the firewire bus, resulting in no end of woe when capturing. Removing the firewire drive was the cure. Worth a try?
I have done a little browsing on your behalf and can see that in fact a lot of people have had troubles with HV20s and HV30s when it comes to capturing - and not just with Vegas. For many, using HDV Split was the answer, for others it was to install all the software from the CD/DVD supplied with the camera, others got it working with alternative firewire drivers. Others never had any joy (sorry).
Old October 19th, 2011, 10:01 AM   #19
Old Boot
Originally Posted by Ian Stark View Post
Tim...., when attached to the card at the same time as my firewire drive, caused what someone described as a 'data storm' on the firewire bus, resulting in no end of woe when capturing.
Hence my question as to the usage of the TWO F/W ports.
Grazie
Old October 27th, 2011, 02:30 AM   #20
Tim, did you ever get this sorted?
Old November 3rd, 2011, 07:46 AM   #21
Not yet Ian but thank you for your help I will try your suggestion. Along with this issue I am also sorting out all the oher woes changing over to a new PC has caused such as re-calibrating my monitor for both still images and video and getting my eyes used to the change to an acceptible degree. And there are a few other sticklers the new system is giving me for sure My inexperience is frustrating to say the least.
www.socalt.com
Tim Cee is offline   Reply With Quote
Old November 3rd, 2011, 05:23 PM   #22
get a spyder and calibrate your monitors properly. you'll be glad you did!
www.lesliewand.com.au
Leslie Wand is offline   Reply
