Capturing Live footage at DVinfo.net
Old July 27th, 2011, 07:34 AM   #1
I am filming church services and my Firestore quit working. I was wondering if there is a way to hook by pc to the firewire port of the camera and download directly into the capturing application in Vegas while the church service is going on. I have Vegas 10 32 bit on my laptop with a Solid State hard drive, so I should not have problems with dropped frames. I don't see an option to do this clearly, maybe I am just looking at the wrong place.
Anyone that has a response - positive or negative?
Chris Barnes.
Chris Barnes is offline   Reply With Quote
Old July 27th, 2011, 09:54 AM   #2
Sponsor: JET DV
Re: Capturing Live footage
Yep. Just use the Vegas capture program and turn OFF "Device Control".
Old July 27th, 2011, 11:12 AM   #3
Edward, I am a little dense on this issue. You are saying when it asked to start at the beginning of the tape or a the point it is at, just disable this question and to start it, hit the record button in Vegas as you hit the record button on the camera?
Old July 27th, 2011, 11:47 AM   #4
Jubal 28
In the video capture program: Options>Preferences>Uncheck "Enable DV device control." Then, yes, you'll record by pressing the record button.
David Jimerson is offline   Reply With Quote
Old July 27th, 2011, 12:02 PM   #5
Thanks, will test tonight.
Old July 27th, 2011, 12:25 PM   #6
I can verify that it works exactly as Edward described it.
I've used this method to record (with a desktop computer to an external USB drive) events that were up to 3 hours or longer with no problems at all.
Old July 27th, 2011, 02:35 PM   #7
Sponsor: JET DV
We do something similar at our church. We have multiple cameras coming into a switcher. The switcher then goes via S-Video to a Panasonic DV-2000 deck. The deck is connected to a computer via firewire and we capture the church service live. Because I'm not the person doing this at the time we go live, I opted for a simpler program to use for capturing. We use Scenalyzer Live for this purpose but the built-in Vegas capture will still work fine.
Old August 1st, 2011, 08:35 AM   #8
Thanks guys, I used it this past weekend and it worked very well.
Chris
Old August 1st, 2011, 08:37 AM   #9
Very glad to hear that Chris.
You have to love it when things work as you hoped they would :)
Mike Kujbida is offline   Reply
