60p DVD at DVinfo.net
Old July 20th, 2011, 03:12 PM   #1
60p DVD
I just rendered out a 720 60p video file to mpeg 2 for DVD, and used 30p for setting. Results are fair, but would be much better at 60p.
Can I use a 60p mpeg 2 file for DVD (I think it is possible) and if so, how can I set rate of 60 in Vegas for rendering? I cannot customize the frame rate in Vegas templates, but have tried various way of doing so. I swear I've done it before, but I can't make it happen today
Old July 20th, 2011, 04:49 PM   #2
Jubal 28
Re: 60p DVD
There is no 60p in the DVD spec. It'll be 60i. Even if you render a 60p MPEG-2, DVD Architect will re-render as 60i.
Just use the DVD Architect NTSC Widescreen template. Set render quality to Best because you're resizing.
David Jimerson is offline   Reply With Quote
Old July 20th, 2011, 05:56 PM   #3
Re: 60p DVD
Thanks for your reply David, appreciate it very much. I just played it as rendered and it looks pretty darned good, I'm just used to HD now, I guess.
