Clip marking at DVinfo.net
Old July 11th, 2011, 02:48 PM   #1
Clip marking
This is probably one of those fundamentally dumb questions but is there a way to place a mark on a seperate audio and video track for the purpose of syncing them up? I use to be able to do this in Liquid and it was great for me. I know you can place a marker on the timeline in vegas but that is not what I need. I need the mark actually on the audio and video clip.
Thanks a million!
Jeff
Jeff Green is offline   Reply With Quote
Old July 11th, 2011, 03:30 PM   #2
Sponsor: JET DV
Re: Clip marking
Add the markers in the TRIMMER and then align those markers on the TIMELINE.
Old July 11th, 2011, 10:29 PM   #3
Re: Clip marking
Snap offset was designed for such tasks.
From the help file:
"Each event has a snap offset flag that you can move along the event's length to fine-tune where snapping will occur. To adjust the flag, drag the white triangle in the lower-left corner of the event. A ToolTip displays the amount of offset."
Aleksey Tarasov is offline   Reply With Quote
Old July 12th, 2011, 03:21 PM   #4
Re: Clip marking
After a decade of using Vegas I finally learned how to put regions on clips rather than on the timeline, so that they move with the event! I don't recall any occasion where I have ever used the trimmer but I can see it's going to be a frequently used tool from now on. Thank you Edward!
Ian Stark is offline   Reply With Quote
Old July 13th, 2011, 06:53 AM   #5
Sponsor: JET DV
Re: Clip marking
Glad I could help, Ian. I almost never use the trimmer. But it does have a few uses and for those few times I need it, I use it. For normal cutting, I just drop everything on the timeline and cut away.
If you have markers/regions on the clip and you want to move them to the timeline too, you can run the "Promote Markers" script.
Old July 13th, 2011, 06:57 AM   #6
Re: Clip marking
Same here. Until now I could never see the point of the trimmer! Thanks again.
