No luck ripping DVD's into Vegas using AutoGk - Page 2 at DVinfo.net
Old February 19th, 2006, 03:42 PM   #16
Originally Posted by Eric Stromblad
Any ideas on the ac3 for vegas? I don't want to convert to wav and loose the 5.1 surround sound. I don't want to go back to my old capture method either because that was pulling it in through rca stereo and destroying the 5 channels also. This isn't the case of a weird format of ac3 either, I tried several different formats. Also, ac3 isn't listed on the pulldown list of media choices so I know something is missing....it's not working in movie studio either.
The demo version of Vegas won't decode the AC3. Once you purchase it, it will do so
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old February 19th, 2006, 03:49 PM   #17
Do you mean vegas video or vegas movie studio?
I have the full version of vegas video 6, but just downloaded the demo of vegas movie studio. Also, I patched 6.0d just now and it still doesn't pull in ac3 files, however, it does pull in the audio and video when I use a vob file (unseperated, direct stream copy). So that would work just as well....except as someone else mentioned it is out of sync...and not just by a few frames that I could bump over...the whole thing is skewed. I will try womble next to see if that handles it better.
Eric Stromblad is offline   Reply With Quote
Old February 19th, 2006, 08:46 PM   #18
Sponsor: JET DV
Neither will open AC3 files. However, both will open AC3 audio embedding on a DVD (as you've discovered).
Old February 19th, 2006, 09:37 PM   #19
As Edward mentioned, neither program will open *just* the AC3 file, both will open AC3 embedded in the VOB, but not a separate file. This was intentionally done to help keep Vegas from being a part of the workflow making it easier to pirate DVDs.
Old February 20th, 2006, 01:35 AM   #20
two options
I've tried a million things and it seems I'm down to two options:
1-Continue trying to use some kind of converter to get my files into vegas video...
-dragging in VOBS bring the audio in with 2 channels and unsynched
-using virtual dub mod brings in even better picture (but with 5 channel audio that doesn't even work) and a 5 min. file is 7 gigs
-using virtual dub mod with direct show avs avisynth template (the only avisynth template that works) brings in a great picture with 2 channel audio that is out of sync and the 5 min. file is 8 gigs
-IM too dvd ripper 4 (demo version) was just as dissapointing: raw avi compression won't go into vegas and huffy looks very pixelated.
-also, several of those failed attempts have brought in video at 23 frames instead of 29.97....from no option that I checked off
Has anyone here ever been able to drag and drop or convert from the dvd rom and bring into vegas a 29.97 beautiful looking video and 5.1 channel audio as it originally was on the DVD - all nice and synced up?
2-Or I could abandon vegas for a little while and go the woomble way:
-Woomble does edit the vobs with 5.1 sound perfectly. The way it edits native dvd video really is innovative. However, when I export back to DVD (and I've tried every different method) it says that I'm exporting a 29.97 ntsc mpeg with 5.1 ac3 encoded sound. However, when I bring it in to DVD architect it reads the file as a 23 frame per second video with 2 channel audio file....wtf?
-before I spend any more time with those bugs, I have to decide if I'd want to edit with woomble in the first place. The quality is what I'm looking for but the interface is so bad I don't know if I can use it....It makes U-lead look like final cut pro. It's just aweful...I don't even think there is a way to seperate audio and video...let alone make L or J cuts. I couldn't even find a gap tool.
-as far as I know I have the new, full version and it is freeware.
Does anyone know another program like woomble that can treat those 4 gig DVD video files just like it was uncompressed video, yet has an interface thats at least a little less pathetic? I'd pay anything for that, right about now.
