Thread Tools
Search this Thread
#16 | |
Re: Blur/motion/ghosting lines on video? How to fix
So, basically, if I shoot at 24 fps I should choose HD 1920x1080 24p in the timeline and 24 fps (FILM) as the frame rate in my time-line? When I render I should render (for the internet SONY AV) I should choose 920x1080 24p with a frame rate 23.976, progressive? For DVD I choose DVD architect. Each should, then, be selected at Progressive scan. That seems to be what I am getting now. |
#17 |
Jubal 28
Yes, use that timeline for your 24p footage. But no, don't choose 24.000 for the frame rate, choose 23.976.
The frame size for rendering out depends on what you're doing, but 23.976 progressive is pretty much always going to be your frame rate.
www.wrightsvillebeachstudios.com |
#18 |
I have also been using:
/ PIXEL RATIO at 1,000 / BITRATE 2,000,000 Is this about right? |
#19 |
Jubal 28
The PAR is correct. Bitrate depends on what you're doing with it.
Generally, the render templates are optimized for the purposes they're named for.
