Ram render setting in V10 at DVinfo.net
Old May 24th, 2011, 06:33 PM   #1
I'm setting up Vegas 10 on a new computer and can't remember how to fix this...I know it's something simple...if I highlight a section to Ram render, then click 'shift + B', the highlighted section changes to the start of the clip. What do I need to change? Thanks in advance.
Herm Stork is offline   Reply With Quote
Old May 25th, 2011, 04:25 PM   #2
Re: Ram render setting in V10
Herm,
As well as selecting the clip, you have to mark the area of the clip that you want to ram preview.
Double click the clip and you will see at the top of the timeline a grey line appear with two yellow arrows at either end, this is the Loop Region, move the arrows to cover the area you want to preview and then press your shift+B.
I think this is what you are asking!
Regards
RichardG
Richard Green is offline   Reply With Quote
Old May 26th, 2011, 12:31 PM   #3
Re: Ram render setting in v10
I didn't explain this very well...I have created a "loop" region. I have "render loop region only" checked. When I click shift + B, the loop region changes, extending the left side to the begining of the clip and it does not render anything.
Old May 26th, 2011, 05:06 PM   #4
Hi Herm,
Looks like vegas 10d Dynamic Ram Preview is broken. I just tried what you described and sure enough it has a mind of it's own. So tried it in 10c and it works as you and I expect, perfectly!
Having said that, my version of 10d is on a machine with windows 7 installed and my 10c version is on
a totally different slower machine running XPpro.
So we need other people to come in here and confirm one way or the other, any takers?
Regards
RichardG
Old May 26th, 2011, 05:34 PM   #5
shift+b working fine here 7/64 with 10d/64
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old May 26th, 2011, 05:41 PM   #6
I thought it may be a 10d issue.
Old May 27th, 2011, 01:16 AM   #7
Thanks Leslie,
I'm using 32bit vegas 10d on win 7
RichardG
Old May 27th, 2011, 10:33 AM   #8
More info...I'm using windows 7/64 with 10d/64. I can't figure out the solution.
Old May 27th, 2011, 10:48 AM   #9
This problem has been reported by a few users on the Sony Vegas forum too so it definitely sounds like a bug.
Best bet is to send an email to Tech Support outlining your problem in the hopes that they can come up with a fix.
Old May 27th, 2011, 01:06 PM   #10
I have done, Mike.
Not heard anything yet.
Regards
Richard
Old May 27th, 2011, 01:30 PM   #11
Be very patient Richard.
Some posters on the Sony forums are saying that they've waited 10 days or longer before hearing anything.
Not even a "thanks, we got your email" notice to acknowledge that they got it :(
Old May 28th, 2011, 01:12 AM   #12
Hi Mike,
I know what your saying, but a few weeks ago I posted to them another problem I had with vegas and they were very prompt with their answer (didn't cure the problem though). And I've always had confirmation of my queries. It might be that I'm on their primesupport list.
We shall see, not holding my breath.
Richard
Old May 28th, 2011, 01:28 PM   #13
You can re-assign Dynamic Ram Preview to another key combination using Customize on the menu.
I had the same problem, I believe there is an plugin/effect package which 'steals' the shift-B combination, but I have no idea which one it could be..
Magnus Helander, Crossmediageek on G+
Magnus Helander is offline   Reply With Quote
Old June 23rd, 2011, 04:02 PM   #14
If anyone is still interested, I have been in lengthy communication with Sony about the above problem, had to send some video and screen grabs to show/prove what was/is happening. I've set up another computer on win 7 64bit installed vegas 10d on it and still get the same problem.
This is the latest post I've had from Sony regarding this issue:-
"Hi Richard,
Thank you for writing back.
Because this incident involves very detailed technical aspects of the programming and design of our software, I will be consulting with our Development and QA team to try and resolve this issue.
Please understand, that because this issue is so technical in nature, and because these other teams have a rather large workload, it may take some time to solve this problem. I will be setting this incident to development status during this time and will update this incident once I have further information from them. Thank you for your patience while we continue to research this matter.
If you still have a follow-up question on this particular incident, please feel free to update it. If you have a completely different question, please create a new incident.
Sincerely,
Nate P.
Customer Service & Technical Support
Sony Creative Software Inc
www.sonycreativesoftware.com"
Richard
Old June 27th, 2011, 02:10 PM   #15
And below from Sony is to confirm what I thought.
Hi Richard,
I spoke with our development team on this. They are aware of the bug and have logged it in the system. I would suggest that you continue to download any updates that come out for Vegas. If for some reason you still see the issue, please submit another incident and reference this one: 110527-000002.
Sincerely,
Nate P.
Sony Creative Software - Vegas video - ACID & Sound Forge audio editing
Regards
RichardG
