#16 |
Sponsor: JET DV
Re: Vegas and Slow-motion
That's why I added a "freeze frame" option in Excalibur! :-) You can set the cursor at the point you want to freeze and it's a simple click to add the proper envelope points. I agree, though - I've frequently looked for a 0% preset and ended up having to type it until scripting came along.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
#17 |
Edward, thanks so much for that! I've never looked into the Set Velocity function in Excalibur. In fact, there is so much in Excalibur that I've never explored properly.
You know what would be really cool - if you could assign specific functions to icons, i.e. have whatever is saved as the default for each function available as a button on the task bar. There are perhaps five or six Excalibur functions that I use every single day and to have them a click away would be extremely useful. |
#18 |
Sponsor: JET DV
Go to View - Extensions - Excalibur - Individual Tools and look at that list. All of those items can be added to the toolbar as clickable buttons. So you CAN add "Vel - Velocity" as a clickable button and it would use the default values you set meaning it could be a "freeze frame" button. All of those items are selectable for both adding to the toolbar or setting to a keypress.
#19 |
Well my day just gets better and better. Many thanks!
#20 |
Sponsor: JET DV
Amazingly enough, it's described on page 6 of the manual ;-)
#21 |
"Man-u-al"?
Heard of it. Don't think we get them over here ;-) Hint taken, Edward. I will read it forthwith! |
#22 |
Good afternoon,
Using velocity envelope is a bit of a pain. Before I had excalibur, I would copy the clip change the velocity on a different track then insert it where i wanted it!! Excalibur of course allows to the adjust it more precisely more easily and adjusts on the track perfectly. Another method I did not see mentioned (but I did not read all the posts closely) is to shoot at 60i (60 P if you have it) set the project settings to progressive, interpolate upon deinterlace. That then gives you the ability to adjust the Play rate to what ever you like. I have even done this and compounded it with Velocity envelope as well. If you play around with these two you can get some particularly good slo motion at times. Twixtor would be a nice asset.
DATS ALL FOLKS Dale W. Guthormsen |
