2 different formats on same timlene
Hi. I am in PAL land and have to make a 2 camera edit. One camera shoots HDV 1440x1080 50i and the other 1280x720 25p. Should I put both .mt2 files as they are on the timeline or should I change the format of one of them, using Reference, and then put 2 files with the same proprties on the timeline? And if I was to go with the first option (not changing formats), what would be the best properties setting for my Vegas project? I have some ideas on this but would like to hear other opinions. Thanks a lot
Sponsor: JET DV
Re: 2 different formats on same timlene
First set your project properties to the desired output format. Then just drop both original clips onto the timeline and edit away...
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
Interesting!
Ed if i have 1440x1080 50 i and 1920x1080 24p and my final output is 1440 x 1080 50i i aask you if i have to change anything on the 24p clips (that are just few). For example should i "resample" anything? Thx |
Sponsor: JET DV
Just test it both ways and see which works better for your footage.
#5 |
No matter which way you do it, always Disable resample on all clips.
I've yet to find a project that looks better with resampling. Try this, Disable resample on all clips, Go to properties and set ruler to absolute frames. Is it better?
http://vimeo.com/livewebvideo |
#6 |
tpmorrow i ll try!
yhx |
