Conforming 25 p videos with 50i videos for a documentary at DVinfo.net
Old March 17th, 2011, 11:10 AM   #1
Hola guys,
i was thinking what's the best bet to conform videos from a camera shot in 25 p with videos shot with a Sony hdv camera in 50 i.
What kind of problems could i encounter? I wanted to use the awesome dof of the 50mm lens with the rest of the videos shot with fx1 and z7.
Please help
thx a lot
Old March 17th, 2011, 07:36 PM   #2
Re: Conforming 25 p videos with 50i videos for a documentary
Do you want to export interlaced or progressive?
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old March 18th, 2011, 04:34 AM   #3
The most of the videos is composed by hdv 1080 50 i clips......
there a re few inserts with hdslr files 25p.
So what would be the best choice?
thx
Old March 18th, 2011, 05:03 AM   #4
Disable smart RESAMPLE in clip properties on the 25p clips and see if that helps.
Old March 18th, 2011, 02:54 PM   #5
This is just what I would do.
If you make everything progressive you can maintain that right through to delivery, whether it be web or DVD.
So, easy way is to just have a progressive project and have 'Interpolate fields' selected in Properties. This will take care of any interlacing that occurs from your 50i footage.
A better way if you have time, is to drag all your interlaced footage into a Progressive project and select Interpolate fields. Then save this project as, (make up a name.)
Then drag that Veg file into another 25p project that is set to Progressive frames.
The benefit of this, is that you take care of your interlacing issues in the saved Veg, but you're not messing around with the interpolation (therefore degrading the quality) of your nice clean progressive footage.
Just a thought, wouldnt it be good if you could make a new media bin and apply your clip property choices to that Bin..... Maybe Vegas 11.
Old March 19th, 2011, 03:40 AM   #6
Wow now i know how i have to try a few things on this weekend!
thx guys
Marcus Martell is offline   Reply
