Mainconcept Mpeg custom key!!!! at DVinfo.net
Old August 13th, 2005, 01:00 PM   #1
Hi guys, seem to have lost the ability to change any mainconcept MPeg2 settings using the custom key, The button depresses but does nothing..?????
I have all the standard templates there to use, but just can't custom any of them..??
Any thoughts.?
I have re-installed vegas but this hasn't fixed the problem..
Thanks Mike
Mike Hardcastle is offline   Reply With Quote
Old August 13th, 2005, 02:57 PM   #2
Sponsor: JET DV
Check out this possibility from my FAQ
Look in your registry, and make sure it only has these entries, and nothing else.
[HKEY_LOCAL_MACHINE\SOFTWARE\Sony Media Software\MC MPEG Plug-In\1.0\License]
"CurrentKey"="XX-XXXXXX-XXXXXX-XXXXXX"
"InstFlags"=dword:00000010
(you shoud see letters and digits instead of the Xs here...)
If it is not "CurrentKey" or "InstFlags", get rid of it.
Old August 13th, 2005, 06:21 PM   #3
Cheers edward, didn't quite work but I deleted the whole MC Plugin registry folder, then once i tried to use the mainconcept again, it asked me for my serial and activation code, and all is well now............
Thanks for the direction.
Mike
Old August 14th, 2005, 07:08 PM   #4
Bugger..............i've lost the custom key again...!!! any other ideas
Mike
Old August 16th, 2005, 02:54 PM   #5
Hey I had the same problem, How do i look in my registry?
Kevin Red is offline   Reply With Quote
Old August 16th, 2005, 03:01 PM   #6
Sponsor: JET DV
Start - Run - Regedit
NOTE: If you don't know what you're doing, it *IS* possible to mess things up by playing in the registry. Care is recommended (or find someone who knows what they're doing and let THEM do it).
Old August 16th, 2005, 08:14 PM   #7
well Id like to try what Mike did by deleting the serial code part then re entering. Mike would you like to tell me how you did this exactly so I don't screw any thing up? Thanks
Old August 17th, 2005, 11:21 AM   #8
Hi kevin, Follow the path that edward wrote in regedit, if you look on the left hand column and open each folder in order until you reach the license/1.0 folder and delete this.
once you open vegas and use mpeg again it will ask you to input serial and away you go....
Mike
Old December 21st, 2005, 12:44 PM   #9
wait a minute...
AMD Athalon 2800 (2.08ghz) running Windows XP sp2
1GB of RAM Vegas 6.0 NLE 300+ GB hard drive space
running SATA RAID 0 With an NVIDEA Geforce FX 5600XT
http://www.dvinfo.net/conf/search.php?searchid=149990
Old December 23rd, 2005, 04:28 PM   #10
I had absolutely the same problem. The ONLY thing that helped me is installing Vegas Movie Studio. Now Vegas 6 doesn't have any problem with mpeg custom key!!!
Plamen Petrov is offline   Reply
