What's the most common reason why Vegas can't render and shuts off? at DVinfo.net
Old February 3rd, 2011, 01:08 AM   #1
Footage is 1920 x 1080 30i, I'm trying to render out to the same quality. I suspect it's my computer that's not up to it. Vegas closes a few seconds after I start the render. My PC: XP, Intel Core 2 Quad Q6600 2.40 ghz, 3.25 GB RAM, hard drive is 750 GB.
This PC was able to render to 1440 x 1080.
Norris Combs is offline   Reply With Quote
Old February 3rd, 2011, 01:10 AM   #2
just the one hd?
how much space?
if so try getting an external and render to that....
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old February 3rd, 2011, 09:17 AM   #3
Oh, I have 2 hard drives. The C drive for the OS and all the program files, E drive is only for my videos. Each is 750 GB.
Old February 3rd, 2011, 11:36 AM   #4
Your PC sounds underpowered for HD. I don't like working with HD on my i7, if that tells you anything.
Some folks use an intermediate program such as Cineform to make file more usable. That would help, but I personally dislike the process, and Cineform can introduce a whole new set of issues, as any software can do.
You have too little ram, a processor that is not optimized for this work, and if your HD is slow, you have a recipe for poor performance.
This would be a good time to buy the i7 processor, as they are inexpensive right now.
Some get by with the Q6600, but I can't imagine how they do it.
Old February 3rd, 2011, 12:56 PM   #5
Originally Posted by Norris Combs View Post
Footage is 1920 x 1080 30i, I'm trying to render out to the same quality. I suspect it's my computer that's not up to it. Vegas closes a few seconds after I start the render. My PC: Thanks,
what footage was shot with, what's 30i, is it 60i? any conversion involved before Vegas?
I love this place!
Old February 3rd, 2011, 07:29 PM   #6
My camcorder is Canon HF-S100. When I imported the video, it shows the resolution as 1920 x 1080 at 29.xx.
Old February 3rd, 2011, 07:31 PM   #7
Please explain why you don't like working with HD on your i7 PC, yet you're suggesting that I should buy one. Thanks,
Old February 3rd, 2011, 07:50 PM   #8
Norris, you don't mention your operating system or which version of Vegas. The main reason for render crashes on 32 bit Vegas - if that's what you are running - is a 2GB memory cap. There are fixes which have been discussed in this forum, see http://www.dvinfo.net/forum/what-hap...y-torment.html
Rainer Listing is offline   Reply With Quote
Old February 3rd, 2011, 10:54 PM   #9
OS is XP. Vegas Pro 8, 32 bit. I didn't know about the 2 GB memory cap. So even though I installed 4 GB, and it shows 3.25 is available for work, only 2 GB are being used?
Old February 4th, 2011, 09:35 AM   #10
Heat
In my experience insufficient cooling on CPU & system is the main problem.
/m
Magnus Helander, Crossmediageek on G+
Magnus Helander is offline   Reply With Quote
Old February 4th, 2011, 09:45 AM   #11
He's running his cpu at stock speed. Cooling should not be an issue. He is running what is now an nearly outdated CPU (at least for hd video) and he only has 3gb of ram. Upping his ram usage will likely do little to help with his current system.
But who knows.
Old February 4th, 2011, 01:33 PM   #12
I'm gonna build a new PC, can you guys suggest some minimum spec for the components? I believe the most important is CPU, motherboard, GPU, hard drives. If you already have a recent setup that works well for you, please list its compnents.
Old February 4th, 2011, 03:12 PM   #13
Yes. Do the memory hack and you should be sweet.
Old February 5th, 2011, 06:27 AM   #14
I'ver used the guides from these "guys" a couple of times:
Videoguys Blog - Videoguys' System Recommendations for Video Editing
Leif Skoglund is offline   Reply With Quote
Old February 6th, 2011, 08:03 AM   #15
I wrote down some of my experiences with vegas, starting from v4 2003 ...
Magnus Helander - random findings / Optimizing Sony Vegas editing
/m
