Preparing File for DVDa? Why r the Themes disappearing? at DVinfo.net
Old January 31st, 2011, 09:33 AM   #1
I am trying to make my first DVD from Sony Vegas Pro 8.0
I have downloaded the most recent trial version of DVDa 5.2
here are my questions:
1 If I have a file size of 1280x720 do i need to re render it at 720x480 before bringing it into DVDa? I am rendering the file i bring into DVDa as an AVI file is the correct?
2 When i open DVDa I can see themes in the THEMES window...I select File>New>Single Movie>(MPEG-2 720x480-60i, 16:9 NTSC) then when i select my video file the Themes window says "No themes available"
3 In preview the video is there and the chapter markers are working but there is like 1/8" of letter boxing on both sides of the video
Do I have my settings goofed up or what?
Vegas 8.0c (Build 260)-(Upgraded to Sony Vegas 10 pro)Canon GL2, Canon HV30, HF200, HF20-Sony UWP Wirelesss Mic Kit, Intel Core 2 CPU-6600@2.40GHz-3.00GB Ram
David Ruhland is offline   Reply With Quote
Old January 31st, 2011, 10:21 AM   #2
1. Yes to a re-render if this is not Blu-ray.
Ideally, using the appropriate templates, you render two files, MPEG-2 for video and AC-3 for audio.
2. A "Single Movie" doesn't have a theme.
3. Correct #1 and this should go away.
I highly recommend reading Vol. 1 Issue #7 of Edward Troxel's free newsletters as this issue deals with this exact topic.
While written for earlier versions of Vegas and DVDA, everything is still applicable.
Old January 31st, 2011, 11:39 AM   #3
Thanks. Printing the newsletter now
