1280x720p to put on Blu-ray at DVinfo.net
Old January 28th, 2011, 02:00 PM   #1
My footage is 1280x720 25p. The format is HDV in a .m2t file. To what format should I render from Vegas Pro 8 in order to have a compliant Blu-ray disc?
George Palmier is offline   Reply With Quote
Old January 28th, 2011, 02:39 PM   #2
There should be render presets in the render window. Did you check? Look in mpeg2.
Old January 29th, 2011, 05:02 AM   #3
My problem is which preset to choose. There is one which is "HDV 720-25p". This will produce a .m2t file which I don't think is Blu-ray compliant. In the blu-ray preset list there is no 720-25p. Should I use 1440x1080 50i? Would this produce a lesser quality image since it is at a higher resolution then my original 1280x720 25p?
Old January 29th, 2011, 10:18 AM   #4
For 1280x720, you will need to convert 25p to 50p for Blu-ray compliance. The official Blu-ray Disc specification does not support 25p or 30p at any resolution. Some studios have managed to successfully convert 25p to 24p - but that would have required specialized equipment to do the job correctly.
Randall Leong is offline   Reply With Quote
Old January 29th, 2011, 12:24 PM   #5
Specialized equipment? In most cases you would just declare the video to be 24p (so an hour's worth of video will play in an hour plus two and a half minutes, a difference no one will ever notice) and resample the audio to match.
I mean, didn't the PAL DVDs just speed up film by 4% (much to the annoyance of sound people)? This would just do the same but in the opposite direction.
Here is the math behind it: One hour (60 minutes) of 25p played at 24p will take 60 * 25 / 24 = 62.5 minutes to play.
Adam Stanislav is offline   Reply With Quote
Old January 29th, 2011, 11:42 PM   #6
Randall I totaly agree with you that 25p is not blu-ray compliant. And in fact that is my problem!! Can anyone please tell me which preset to use in Vegas Pro 8 to convert my 1280x720 25p in order to put the video on Blu-ray?
