Can I send someone one of my custom templates? at DVinfo.net
Old January 20th, 2011, 12:30 PM   #1
I assume that Vegas saves render custom templates as files somewhere.
I was wondering if it is possible to create a render custom template and then locate the file which consists of that template and send the file to someone (by email for example) for him/her to use on their computers. If it is possible, I'm guessing the recipient would then have to import my custom template into his/her Vegas application or drop the file in a folder somewhere so that "my template" then appears in the list of render templates available. Can this be done (Using Vegas Pro 9e)?
Adi Head is offline   Reply With Quote
Old January 20th, 2011, 02:54 PM   #2
Sponsor: JET DV
I think it's actually a combination of files on the hard drive and settings in the registry. The simplest way may be to just take snapshots of the screen showing the settings you're using.
Old January 20th, 2011, 03:38 PM   #3
ok. yeah that's (screenshots) what i've been doing so far. thanks
Old January 20th, 2011, 04:08 PM   #4
Looks like they're located here: %username%\AppData\Roaming\Sony\Render Templates
Can they be shared? I dunno.
...Jerry
Jerry Amende is offline   Reply With Quote
Old January 22nd, 2011, 12:20 AM   #5
Screenshots need to be saved as an image file, usually in MS Publisher and then upload the pic on here.
Lee Mullen is offline   Reply With Quote
Old January 22nd, 2011, 12:26 AM   #6
m$ publisher!?
if you're on win 7 > snipping tool.....
Leslie Wand is offline   Reply With Quote
Old January 22nd, 2011, 09:53 AM   #7
Mine was free.
Old January 22nd, 2011, 10:59 AM   #8
Yes this can be done.
I've created custom render templates on my work computer, brought them home and installed them.
I've done the same thing in going from home to work.
Using XP Pro, here's where they are on my computer.
Pro 9 and earlier:
C:\Documents and Settings\Mike\Application Data\Sony\File Templates
Pro 10:
C:\Documents and Settings\Mike\Application Data\Sony\Render Templates
If you use Vista or Win 7, do a search on the file type for the location.
Note that Pro 9 uses an *.sft extension while Pro 10 uses *.sft2 and the two are not compatible :(
Mike Kujbida is offline   Reply
