image sequence? at DVinfo.net
Old December 14th, 2010, 12:36 PM   #1
image sequence?
I can not find the right way to pull an image sequence into Vegas. What is the trick?
Jack Duggan
Jack Duggan is offline   Reply With Quote
Old December 14th, 2010, 01:13 PM   #2
Go to File > Import, browse to the correct folder, click on the first image in the sequence, click the "Open still image sequence" box at the bottom of the tab and click "Open".
Change any desired options in the box that comes up and you're done.
All the images have been combined into a single file sequence that can be dropped anywhere on your timeline.
Old December 14th, 2010, 06:36 PM   #3
Thanks Mike, I knew it was something simple I was missing.
Jack Duggan
