Vegas10 + Decklink intensity at DVinfo.net
Old November 23rd, 2010, 12:03 PM   #1
I was using BMD Decklink intensity pro with vegas 8Pro, 9Pro (with old Decklink firmware+driver) - but cant get vegas10pro working with it.
Anyone?
Regards
ULi
Uli Mors is offline   Reply With Quote
Old November 24th, 2010, 02:56 AM   #2
Just checked mine and all is good.
I did update the Blackmagic Intensity firmware a week or so ago, maybe try that?
good luck.
Just one thought, in the Capture window pref drop down, just check that you have the same pre set checked as what you are trying to capture, if your stream is, say, SD Pal, and your capture pre set in Vegas is 1080 50i, its a no go, just black screen.
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old November 24th, 2010, 09:46 AM   #3
HI,
I even cant set the capture from vegas ("no device")
can you set the intensity for preview? Does it appear (and work) in the preview devices window?
Can you check what driver you are using?
Thanks (you are my last hope...)
Uli
Old November 24th, 2010, 10:53 AM   #4
- solved -
Uninstalling Vegas (10) does not delete some Sony Folders. In one of these folders the old driver was placed - and a new installation does not overwrite it.
So finally ;-) I deleted the Vegas10Pro folder and installed vegas from scratch.
NOW IT WORKS (with the actual firmware/driver).
thanks!!!! - with your help I knew that it should somehow work - otherwise IŽd given up...
ULI
Old November 24th, 2010, 01:32 PM   #5
Glad you solved it.
