Changing from 32 to 64bit at DVinfo.net
Old September 13th, 2010, 11:55 AM   #1
Quick question. I'm in the middle of a project but won't have my audio file now till November. I want to upgrade my OS to Win 7 64bit and then upgrade Vegas 9e to 64bit. All my project files are on separate drives from the OS. Can I assume that I shouldn't have any problems opening up the project in a new 64bit install? Has anybody done this without any problems? Thanks.
David Stoneburner is offline   Reply With Quote
Old September 13th, 2010, 12:01 PM   #2
Sponsor: JET DV
You should be able to transfer files back and forth between the 32-bit and 64-bit versions of Vegas. The only real "catch" is if you're using any 32-bit only plugins. Are you?
Worst case, you can always also install the 32-bit version. The two versions can safely live together on the same machine.
Old September 13th, 2010, 12:34 PM   #3
No I don't think I am. I haven't been using any plugins. I was going to possibly use some color correction presets. I don't think they are specific to 32 or 64bit.
Old September 13th, 2010, 12:38 PM   #4
Sponsor: JET DV
None of the built-in Sony effects should cause an issue.
Old September 13th, 2010, 03:45 PM   #5
Magic Bullet is the only software I've encountered thus far that doesn't support the 64bit version of Vegas.
Frank Grumeretz is offline   Reply With Quote
Old September 14th, 2010, 01:31 AM   #6
Boris Red is a no go zone as well, fine on a 64bit machine, just not 64bit Vegas.
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply
