what's the best format to convert Mp4 to, for use in vegas8) at DVinfo.net
Old August 27th, 2010, 03:37 AM   #1
It's quite rare, but sometimes I need to use Mp4 (for example shot with my iPhone 4 in 720) (I use vegas 8.c) so they wouldn't work.
obviously when using the ex1 I can use the clip browser to transcode to mxf, but when I have other mp4s from other sources, what should I convert them to?
which tool should I use?
Federico Perale is offline   Reply With Quote
Old August 27th, 2010, 06:14 AM   #2
Sponsor: JET DV
I have a GoPro camera that shoots MP4 files - they load just fine into Vegas Pro 9.
Old August 27th, 2010, 06:43 AM   #3
Edward is correct in that Pro 9 had fixes for the ongoing QuickTime issues that regularly plague any non-Mac users, Vegas included.
Some users found that rolling back to QuickTime 7.6.4 (or even earlier) resolved their issues but that doesn't seem to be the case with newer devices such as iPhones :(
Old August 27th, 2010, 06:47 AM   #4
yes I tried that route, problem is if you "downgrade" quicktime the latest Itunes doesn't work so : )
but my question was if I can trancode to another format my mp4 for use in Vegas 8, and if so which one you would use
the problem has been solved in Vegas 9 but I want to stick with 8c
Old August 28th, 2010, 09:43 AM   #5
If you need to transcode, you should use a near lossless file format such as Cineform. Cineform is an intermediate codec that is designed to not hurt the video quality. Delivery formats are inappropriate for intermediate transcoding for editing purposes. They create too many compression artifacts.
Jim Snow is offline   Reply With Quote
Old August 28th, 2010, 04:19 PM   #6
I have to do this all the time, I'm currently working on a clip where I have to use low quality portions of Youtube footage that is in low res MP4 and even FLV, the quality is hideous, I cant afford to make it any worse.
I have Cineform which I would normally use, but until I got that I would render to Lagarith and edit with that, you lose nothing, what you put out is as good as you got.
Lagarith is a bit harder on the timeline preview, you just have Ram preview alot if you have an older machine.
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old August 28th, 2010, 07:19 PM   #7
Cineform is the only one that's worked for me. All the others, like Avid or Matrox either give error messages or are stuttery in preview.
Old August 30th, 2010, 03:51 PM   #8
I think iTunes is so bad, it should be considered malware. I've used MP4's in all versions of Vegas with no problems. (well, the three I've used are Vegas 7, 8, 9). I have the K-lite codec pack installed, along with the "quicktime alternative" driver. That way I don't have to taint my computer with Apple software.
But, if you insist on converting the file, just pick one. AVI, MPG, it shouldn't really matter.
Jeremiah Rickert is offline   Reply With Quote
Old August 30th, 2010, 05:13 PM   #9
Sponsor: JET DV
Most people also recommend against installing codec packs as well.
Old August 30th, 2010, 05:22 PM   #10
I guess I'm not "most people" hehe.
Old August 31st, 2010, 07:59 AM   #11
Sponsor: JET DV
Generally speaking, it's best to only install the few specific codecs you need. By installing a codec pack, some people have literally been unable to load many formats they previously WERE able to load. They can definitely be problematic in some cases.
All I'm saying is - think twice before installing a codec pack and have a means of rolling back your system if it causes problems. And also be aware that some codec packs have included spyware in the past. This may not be the case today but also causes one to be leery.
Old September 5th, 2010, 03:28 AM   #12
Ever tryed TMPENG?
Works very very well
Old September 7th, 2010, 12:37 PM   #13
"All I'm saying is - think twice before installing a codec pack"
Right! And ffmpg killed the ability of my Camtasia to create flash files. Worse yet, it wouldn't uninstall - I had to rename some files that ffmpg had installed in order to kill it.
Larry Reavis is offline   Reply
