Elimination of moiring at DVinfo.net
Old August 23rd, 2010, 10:48 PM   #1
Is there any way to eliminate or reduce moiring of a clip in Vegas? I need to lower the detail setting on my HD cam to prevent this in the future, but I have some clips already done that exhibit moiring and can't be re-shot.
Tom Robertson is offline   Reply With Quote
Old August 24th, 2010, 06:59 AM   #2
Sponsor: JET DV
There are some things. First, you might try turning on "Reduce Interlace Flicker". Then you can add a slight blur to the clip if you need more. Depending on the final destination, rendering as progressive might help.
Old August 24th, 2010, 07:03 AM   #3
Try a small amount of Gaussian Blur.
Adjust Horizontal to 0.0
Adjust Vertical at 0.001 to 0.003
Old August 24th, 2010, 07:30 AM   #4
I'll give those suggestions a try and report back -- thanks guys!
Old August 24th, 2010, 08:21 PM   #5
That worked guys! Thanks!
Old August 24th, 2010, 08:56 PM   #6
Out of curiosity, which suggestion did the trick?
Old August 25th, 2010, 08:54 AM   #7
The gaussian blur seemed to be the way to go with this. I used the settings you suggested with .003 for the vertical. I also did change the reduce interlace flicker setting as Ed suggested, but it did not seem to have much of an effect if any that I could see. There was some minor loss in quality but the clip is much more usable than before -- the moiring was very obvious. I was using an EX1R with the factory default settings. I need to use a profile with the detail setting reduced which I intend to do in the next day or two. I have one that a friend provided me with so I'll try it for now. There are several available here on the forum. This forum has been a GREAT source of help and information. Thanks again, guys!
Old August 25th, 2010, 09:45 AM   #8
Thanks for the update Tom.
It will come in handy if someone is searching for a solution in the future.
Mike Kujbida is offline   Reply
