Where is my Huffyuv go? at DVinfo.net
Old July 8th, 2010, 11:31 AM   #1
Hi guys
Today I downloaded Huffyuv zip file and I unzipped and installed. It show up on my system under add/remove program but not in under vegas. Any one know why? Here the scrêen shot.
PS. Windows 7 64 bit
Bruce Phung is offline   Reply With Quote
Old July 8th, 2010, 07:50 PM   #2
i posted "Installing Huffyuv on Vista 64-bit" a couple years ago... some said it didn't work (for them) but others seemed ok with it... was put together from other postings i'd found on the topic and my own experiences.
http://www.dvinfo.net/forum/what-hap...ta-64-bit.html
yeh i know its Vista, but it should work on Win7 the same... if not, sorry i dunno.
Rob Wood is offline   Reply With Quote
Old July 8th, 2010, 09:46 PM   #3
Originally Posted by Bruce Phung View Post
Any one know why?
Because 64-bit Windows applications cannot run 32-bit DLLs. You would need to run the 32-bit version of Vegas to use the codec.
Adam Stanislav is offline   Reply With Quote
Old July 9th, 2010, 03:10 PM   #4
Thank you guys.
Old July 11th, 2010, 01:36 PM   #5
Yes, but there is also a 64-bit version of Huffyuv available.
You also might want to install the Lagarith codec.
In genereal it's better accepted by host applications.
Lagarith is available as a 32-bit and 64-bit version.
Vincent Mesman is offline   Reply With Quote
Old July 11th, 2010, 04:12 PM   #6
Vincent
Thank you. I did not realized there is a 64 bit Huffyuv, with your reply . I googled it and found it. . I like hufffyuv . I had have lagraith but kinda slow. I did some testing today and Huffyuv wins with a file size slightly bigger.
