Quality loss after rotating video
Hello!
I need to rotate very small my HDV video, about 1 degree. I do this with video event pan/crop. The source video look sharp. After rotated and rendered to HDV template (best quality video setting), the sharpness, details disappear. It has a soft look. I thinked it is because in digital world, it has to be some degrading, nothing is for free. But then i test to render to uncompressed avi and that rotated avi look as sharp as the source. What can i do? Why is this behavior? Unfortunately I need the video in HDV format. It is just because the mpeg recompress? When i change the opacity to 99%, and render it without rotating, there is also recompress but the sharpness remain good! thx! Marton |
this is a good question. anyone else have comments? i have some shot video of se alaska mountains and shoreline that is slight off, and needs to be rotated serveral degrees...process? quality loss if any with cineform int. codec?
Well, if you rotate an image, you're going to have to slightly enlarge it as well, to hide the black edges that you'll get, so there is bound to be a quality loss. It's the same as if you use a software image stabilizer...
Plus the fact that mpeg doesn't like a lot of tweaking in post. A transcode to something like Cineform might be the answer. |
Does switching on Reduce Interlace Flicker for the rotated clip make any difference?
#5 |
i am using neoscene 5.04 intermediate codec, and wondering if i should rotate then in vegas 9 under pan, and save to what kind of file...i actually dont know if i can save to a cineform file codec still while in vegas using cineform files. .newbie..just started editing in the past month.
#6 |
Cineform is also a lossless codec, you would want to save it to Cineform to retain your high quality video.
#7 |
i havent checked yet..meaning that vegas 9 will let me edit the cineform file, and save back to a cineform file after editing instead of a .veg file?
#8 |
You got it all confused. The .veg file will always remain the same regardless of what codec is being used. The rendering and the codec that maintian the video is what you are after.
#9 |
bruce..please explain as i am pretty new at editing in vegas and cineform. my virutal dub download doesnt recognized veg files. so i probabl should deshake footage first, otherwise, edit in vegas, save the file in .veg, then render to a dvd hd in .veg? i need a little explanation if you have time. bill
#10 |
.Veg file will open by Vegas only. You can not use any other program to open .veg file. .Veg file is the Vegas project name itself. 1) Edit your footage, do what ever you want done to your video 2) when you are finished your edit and happy with it and then render it to AVI. 3) Click on custom and select your codec, in your case you would want to select cineform and click ok. 4) finish your rendering. From there you would import your video into Virtual Dub and deshake it or what ever filter you want to use. When you are finish and you would to render or export to AVI again and select your Cineform codec again. This way your video will always be lossless regardless how many times you have been rendering your video. It like a master video file. If you want to output to Blu ray then output to BD. If you want to output to DVD, then select your DV tempate for DVD. You follow me now?.
For example if you render in Vegas to WMV HD or what ever format. Now you have a video file. And you import that WMV HD file into Vegas, make changes or what ever, and then you render your video again, that will cause your video quality loss after many generations. With a lossless codecs, no matter what you do, your video will always be high quality. Cineform is your choice here. Hope this explaination make sense to you. Good luck |
#11 |
thanks bruce that explains it. you would put virtual dub deshaker at the end then after rotating if needed on some not horizontal images, color correction, brightness contrast, the deshake? i will try this approach. bill
#12 |
I have spent more than 8 hrs playing with varies setting in deshaker and I never able to get good results. I have seen some impressive video that has been deshaked, but it ain't work for me. I use Virtual Dub mainly for HD to SD down conversion and the result is very impressive, very sharp pictures.
#13 |
Robin, thanks for your post.
But my video was only rotated, but NOT upscaled! I masked out the edges with black. Now i try render to avi frameserver and encode to mpeg with different program. |
