Multi-event change in and out point? at DVinfo.net
Old June 11th, 2010, 03:16 PM   #1
Is there a way to do this? I have 6 events stacked and need to extend their out points. I can't seem to multi-select and drag the out points. I can group them and do this but this seems counter productive. Any ideas. Thanks.
GH4 + Voigtlander 25mm, Panasonic TM900, Vegas Pro 16, Adobe CC
Kevin Janisch is offline   Reply With Quote
Old June 11th, 2010, 05:49 PM   #2
Just group them. I don't see how this is counterproductive... you can leave them grouped together afterwards it you don't want to go through to break them all up individually again. It takes one extra keystroke once you've selected all the clips so it's not exactly a big deal.
Even extending 6 tracks seperately should only take a few seconds as long as you have snapping on.
John Wiley is offline   Reply With Quote
Old June 11th, 2010, 06:21 PM   #3
So this cannot be done? There isn't a switch or setting somewhere that is preventing this?
Old June 11th, 2010, 10:12 PM   #4
Not directly, to my understanding. When you click, it's going to select just the event you're clicking on.
... I can't seem to multi-select and drag the out points. I can group them and do this but this seems counter productive...
I'm with John on this - pretty darn straightforward (and productive!) when you're using keyboard shortcuts, which are generally key to productivity.
Multi-select.
hit the g key for group.
drag to new length.
hit the u key for ungroup.
Hope this works for you!
Old June 12th, 2010, 06:54 AM   #5
Sponsor: JET DV
Of course... a script could also easily do this task and could work with "all selected events".
Old June 12th, 2010, 09:58 PM   #6
Thanks Ed. Just making sure I wasn't missing something.
