Selecting 24 project template at DVinfo.net
Old May 19th, 2010, 09:46 PM   #1
I've shot an entire wedding at 24fps 1080p with my 5Dmk2. I've converted to Ciineform intermediate AVI from the MOV
When I try to select a project I'm looking for 24fps 720 template. But all i see is 30 and 25? ????
What am i missing?
The video in preview window is ghosting and almost has a moire halo around moving people.....
Are the project properties important before or merely at render time for fps?
TIA
Nashville TN using Canon 5D MK3, Canon 550D, RODE SVM mic, 70-200 f2.8L II IS, 24-105 f4L IS, 50 and 85 f/1.8, Vegas Pro 11, Zoom H4n, Blackbird, Lilliput Monitor, Lightroom
Harry Simpson is offline   Reply With Quote
Old May 19th, 2010, 10:57 PM   #2
Those are just templates. Just select the closest one and then edit it manually.
Adam Stanislav is offline   Reply With Quote
Old May 20th, 2010, 08:12 PM   #3
Where do I edit the project templates. I've edited the RENDER templates but those templates are not showing up in the PROJECT template selection.
Old May 20th, 2010, 08:53 PM   #4
In the project properties, you just click on the frame rate and type in anything you want.
Old May 21st, 2010, 04:11 PM   #5
Adam
you are correct but (as a computer programmer) what doees that really get you? I can type my mother's maiden name in here and how the world is that seting any technical settings?
Old May 21st, 2010, 05:21 PM   #6
I meant you just type in whatever rate you want. So, for 24 fps, type in 24. Or actually 23.976 for the corresponding video rate.
