Vegas Movie Studio Platinum 9b at DVinfo.net
Old May 11th, 2010, 08:36 PM   #1
I convert to cineform from my 5Dmk2 24 fps MOV I tried to find the appropriate project to produce a 720p HD for YouTube/Vimeo. I had found a setting template that worked great with the 30 fps but when I tried to find the right settings, I didn't even see 24 as a choice for the project properties. See screenshot attached
The render can be set as custom but have no idea what optimal settings would be. Do I need to upgrade to Pro?
What are good settings for this - i was under impression that mp4 was the best format for Vimeo/YouTube HD rendering.
Vegas Movie Studio Platinum 9b-no24toselectprojectproperties.jpg   Vegas Movie Studio Platinum 9b-vegas24settings.jpg
Nashville TN using Canon 5D MK3, Canon 550D, RODE SVM mic, 70-200 f2.8L II IS, 24-105 f4L IS, 50 and 85 f/1.8, Vegas Pro 11, Zoom H4n, Blackbird, Lilliput Monitor, Lightroom
Harry Simpson is offline   Reply With Quote
Old May 11th, 2010, 09:35 PM   #2
Images: 32
Your export settings look fine for Vimeo, just make sure to set the bit rate properly - 5,000,000 bps (5,000 kbps) and the audio settings should be AAC 44.100kHz up to 320 kbps, though 128 kbps works. ** Vimeo Compression Guidelines.
Michael Wisniewski is offline   Reply
